주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480 Internal Battery Replacement
필요한 것
  1. Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: 1 단계, 이미지 1/2 Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: 1 단계, 이미지 2/2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Internal Battery Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480 Internal Battery Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480 Internal Battery Replacement: 2 단계, 이미지 3/3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: 3 단계, 이미지 1/2 Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Internal Battery Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T480 Internal Battery Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T480 Internal Battery Replacement: 4 단계, 이미지 3/3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: 5 단계, 이미지 1/2 Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: 5 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 Internal Battery Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T480 Internal Battery Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T480 Internal Battery Replacement: 6 단계, 이미지 3/3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Internal Battery Replacement: 7 단계, 이미지 1/3 Lenovo ThinkPad T480 Internal Battery Replacement: 7 단계, 이미지 2/3 Lenovo ThinkPad T480 Internal Battery Replacement: 7 단계, 이미지 3/3
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Sarah Westberg
회원 가입일: 03/11/19
23,185 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,136개 작성하였습니다
댓글 4개
"What you need" contains a wrong part.
cumledomla - 답글
Hi @cumledomla, I've added the internal battery for this guide. Thanks for pointing that out! The external battery will show up in the "What you need" section because it's imported from the prerequisite guide for the external battery. Hope this helps.
Sarah Westberg - 답글
The "Battery 2" on my T480 does not load. Is Battery 2 the internal or the external battery?
Finn Hove - 답글
Battery 2 is the external battery.
Peter Falk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 31
7일 전: 218
30일 전: 1,108
전체 시간: 33,662
