주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T480s Fan Assembly Replacement
필요한 것
  1. Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Fan Assembly Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T480s Fan Assembly Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T480s Fan Assembly Replacement: 2 단계, 이미지 3/3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Fan Assembly Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T480s Fan Assembly Replacement: 3 단계, 이미지 2/2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: 4 단계, 이미지 1/2 Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: 4 단계, 이미지 2/2
    • Use the spudger to disconnect the fan cable from the motherboard.
  5. Lenovo ThinkPad T480s Fan Assembly Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad T480s Fan Assembly Replacement: 5 단계, 이미지 2/2
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  6. Lenovo ThinkPad T480s Fan Assembly Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T480s Fan Assembly Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T480s Fan Assembly Replacement: 6 단계, 이미지 3/3
    • Lift the thermal fan assembly from the system and remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sarah Westberg
회원 가입일: 03/11/19
23,330 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,410개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 81
전체 시간: 3,165
