주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T560 Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • Using the spudger, slide the keyboard up towards the display at the notches created for this purpose.
  2. Lenovo ThinkPad T560 Keyboard Replacement: 2 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the six 3.5 mm screws that secure the keyboard to the laptop.
  3. Lenovo ThinkPad T560 Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T560 Keyboard Replacement: 3 단계, 이미지 2/2
    • Using the spudger, push the keyboard toward the display and then slide it back out of the connector at top of the keyboard to remove.
    • Don't pull on the keyboard as it is attached by two ZIF connectors underneath.
    • Flip the keyboard over to expose the keyboard's connections to the motherboard and touchpad.
  4. Lenovo ThinkPad T560 Keyboard Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad T560 Keyboard Replacement: 4 단계, 이미지 2/2
    • Using the spudger, open the latches securing the keyboard's connections to the motherboard and touchpad.
    • Remove the keyboard.
결론
Jackson Reynolds
회원 가입일: 02/27/22
517 평판
안내서 5개 작성하였습니다
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G3
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 52
전체 시간: 1,705
