소개
Welcome to the hard drive replacement guide for the Lenovo Thinkpad T580.
This guide will detail the steps necessary to replace the hard drive.
The most common reasons why this component would need to be replaced is because:
- Your hard drive is full
- Your BIOS indicates your hard drive is damaged
If you are not experiencing these problems with this component consider examining the troubleshooting page for this device.
There are no specialized skills required for replacing the hard drive.
필요한 것
Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
Using a spudger, flip up the locking black tab of the hard drive ZIF connector.
Pull the hard drive cable out from the connector on the motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
