주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T580 Trackpad Replacement
필요한 것
  1. Lenovo ThinkPad T580 Trackpad Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T580 Trackpad Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T580 Trackpad Replacement, External Battery: 1 단계, 이미지 3/3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Trackpad Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T580 Trackpad Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T580 Trackpad Replacement: 2 단계, 이미지 3/3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Trackpad Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T580 Trackpad Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T580 Trackpad Replacement: 3 단계, 이미지 3/3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Trackpad Replacement, Bottom Case: 4 단계, 이미지 1/2 Lenovo ThinkPad T580 Trackpad Replacement, Bottom Case: 4 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Trackpad Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T580 Trackpad Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T580 Trackpad Replacement: 5 단계, 이미지 3/3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Trackpad Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T580 Trackpad Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T580 Trackpad Replacement: 6 단계, 이미지 3/3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Trackpad Replacement, Internal Battery: 7 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 Trackpad Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T580 Trackpad Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T580 Trackpad Replacement: 8 단계, 이미지 3/3
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 Trackpad Replacement, Trackpad: 9 단계, 이미지 1/2 Lenovo ThinkPad T580 Trackpad Replacement, Trackpad: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    구매
  10. Lenovo ThinkPad T580 Trackpad Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad T580 Trackpad Replacement: 10 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, remove four 2.2 mm screws holding the trackpad.
    • Pull the trackpad out.
결론
Ben Elkayam
회원 가입일: 01/23/20
978 평판
안내서 8개 작성하였습니다
Cal Poly, Team S18-G6, White Winter 2020 Cal Poly, Team S18-G6, White Winter 2020 회원
CPSU-WHITE-W20S18G6
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 83
전체 시간: 3,843
