주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement
필요한 것
  1. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: 1 단계, 이미지 1/2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement, Wireless Adapter: 1 단계, 이미지 2/2
    • Orient the laptop so that it is bottom up, and the track pad is closet to you.
    • Unscrew the seven cover screws with a Phillips #00 head screwdriver. These screws will loosen but will stay attached to the cover.
    • Slide the blue opening pick along the side of the laptop and pry off the one clip on each side.
  2. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #00 head screwdriver, remove the 3mm screw holding the wireless adapter to the motherboard.
  3. Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad X1 Extreme Wireless Adapter Replacement: 3 단계, 이미지 3/3
    • Slide the chip to the right carefully until the wireless adapter pops out.
    • Disconnect the grey and black wires by lifting them off straight up until they pop off the wireless adapter.
    • The chip should be completely removed from the computer and you are done.
결론
Beckham Richmond
회원 가입일: 02/10/20
466 평판
안내서 3개 작성하였습니다
Cal Poly, Team S7-G3, Regan Winter 2020 Cal Poly, Team S7-G3, Regan Winter 2020 회원
CPSU-REGAN-W20S7G3
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Hi, does the Lenovo X1 Extreme Gen 1 support Wifi 6 or 6e? If so what which card?
I tried the:
"AX210NGW WiFi Card, Wi-Fi 6E 11AX Wireless Module Expand to 6GHz MU-MIMO Tri-Band Bluetooth 5.3 Internal Network Adapter for Laptop, Support Windows 10/11 64bit, M.2/NGFF"
Wifi worked but Bluetooth wasn't recognized.
Captainturk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 25
전체 시간: 1,828
