주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement
필요한 것
  1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Speakers: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out of the frame and remove it from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Beckham Richmond
회원 가입일: 02/10/20
503 평판
안내서 3개를 작성함
Cal Poly, Team S7-G3, Regan Winter 2020 Cal Poly, Team S7-G3, Regan Winter 2020 회원
CPSU-REGAN-W20S7G3
4 회원들
안내서 8개를 작성함
2가이드 댓글
Could I use the same battery for my X1 Extreme Gen 1 laptop? Thanks.
Huy Tran - 답글
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
Rafael Dolfe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 47
지난 30일: 192
전체 시간: 15,494
