주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X280 Speaker Replacement
필요한 것
  1. Lenovo ThinkPad X280 Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Speaker Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad X280 Speaker Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Speaker Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad X280 Speaker Replacement: 3 단계, 이미지 2/2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Speaker Replacement, Battery: 4 단계, 이미지 1/3 Lenovo ThinkPad X280 Speaker Replacement, Battery: 4 단계, 이미지 2/3 Lenovo ThinkPad X280 Speaker Replacement, Battery: 4 단계, 이미지 3/3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Speaker Replacement, Speakers: 5 단계, 이미지 1/3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: 5 단계, 이미지 2/3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: 5 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove two 5 mm screws from each speaker.
    • Once done, the speakers should still be attached with a red wire connecting to each other.
  6. Lenovo ThinkPad X280 Speaker Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad X280 Speaker Replacement: 6 단계, 이미지 2/2
    • Using the black spudger, push the white plastic connector out of the the tan plug.
  7. Lenovo ThinkPad X280 Speaker Replacement: 7 단계, 이미지 1/1
    • Remove speakers and wiring from device.
결론
Jordan Wooten
회원 가입일: 09/05/21
609 평판
안내서 4개 작성하였습니다
University of Alabama, Team 1-3, Bedsole Fall 2021 University of Alabama, Team 1-3, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 49
전체 시간: 1,504
