주요 콘텐츠로 건너뛰기
Lenovo ThinkPad x120e Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad x120e Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Lenovo ThinkPad x120e Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: 2 단계, 이미지 1/3 Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: 2 단계, 이미지 2/3 Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: 2 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Lenovo ThinkPad x120e Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the two 4 mm retaining screws located on the battery slot.
  4. Lenovo ThinkPad x120e Keyboard Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad x120e Keyboard Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad x120e Keyboard Replacement: 4 단계, 이미지 3/3
    • Flip the laptop back over, showing the keyboard.
    • Using an opening tool, pry open the keyboard starting from the top left. Work your way around until you are able to loosely lift the keyboard.
    • You should see two ribbon wires located beneath the keyboard once you are done.
  5. Lenovo ThinkPad x120e Keyboard Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad x120e Keyboard Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Pull on the black tabs above both ribbon wires using tweezers upwards.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Remove both ribbon wires.
    • Remove the keyboard from the laptop.
결론
Jacob Fronzaglia
회원 가입일: 10/25/21
787 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 UMass Dartmouth, Team 3-4, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 379
