주요 콘텐츠로 건너뛰기
Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement
필요한 것
  1. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Set to Maintenance Mode: 1 단계, 이미지 1개 중 1개
    • While booting, press the F1 button to enter the BIOS.
    • Go to "Config" and then to "Power".
    • Select "Disable Built-in Battery" and press Enter.
    • You will be asked to proceed. Select "Yes".
    • The laptop shuts down.Unplug the laptop from AC.
    • Remove the battery.
  2. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Front Bezel: 2 단계, 이미지 3개 중 1개 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Front Bezel: 2 단계, 이미지 3개 중 2개 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Front Bezel: 2 단계, 이미지 3개 중 3개
    • Start removing the front bezel in the lower display corners using a prying tool.
    • Make sure the glue and tape will stick to the front bezel instead of the display and rear bezel. You can use a gripping tool and a cutter for this.
  3. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Screws: 3 단계, 이미지 2개 중 1개 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Screws: 3 단계, 이미지 2개 중 2개
    • Remove 4 screws M2XL3 with screwdriver.
  4. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Rear Bezel: 4 단계, 이미지 2개 중 1개 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Rear Bezel: 4 단계, 이미지 2개 중 2개
    • Remove the rear bezel with the prying tool.
    • Make shure you do not move or damage the blue and black cable behind the bezel.
  5. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release Display: 5 단계, 이미지 3개 중 1개 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release Display: 5 단계, 이미지 3개 중 2개 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release Display: 5 단계, 이미지 3개 중 3개
    • Carefully release the display, turn it around and place it on the keyboard.
    • Ensure to not damage the connector on the lower part of the display.
  6. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release the Connector: 6 단계, 이미지 2개 중 1개 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release the Connector: 6 단계, 이미지 2개 중 2개
    • Remove the connector together with the label.
결론
다른 19명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Markus Schmidt
회원 가입일: 06/07/15
716 평판
안내서 1개를 작성함
7가이드 댓글
Did this upgrade with my T440 and worked great, used a LP140WF1 / B140HAN01 display added some much needed pixels and IPS viewing angles. I bought from Aliexpress Store: Kevin trade shop.
Ryan - 답글
What about T440s with touch panel?
TINGHUI WANG - 답글
I do not possess a touch device, sorry.
Markus Schmidt -
Can this be done as an upgrade
Randall Bickford - 답글
You mean from “normal” to touch display? I cannot comment on a touch device…
Markus Schmidt -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 89
전체 시간: 32,901
