주요 콘텐츠로 건너뛰기
Lenovo Thinkpad x230 Battery Replacement
  1. Lenovo Thinkpad x230 Battery Replacement, Preparations: 1 단계, 이미지 1/1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 Battery Replacement, Locate the battery: 2 단계, 이미지 1/1
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 Battery Replacement, Unlock the left switch: 3 단계, 이미지 1/3 Lenovo Thinkpad x230 Battery Replacement, Unlock the left switch: 3 단계, 이미지 2/3 Lenovo Thinkpad x230 Battery Replacement, Unlock the left switch: 3 단계, 이미지 3/3
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 Battery Replacement, Remove the battery: 4 단계, 이미지 1/3 Lenovo Thinkpad x230 Battery Replacement, Remove the battery: 4 단계, 이미지 2/3 Lenovo Thinkpad x230 Battery Replacement, Remove the battery: 4 단계, 이미지 3/3
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 3명이 해당 안내서를 완성하였습니다.
Johannes
회원 가입일: 02/25/14
1,010 평판
안내서 3개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 19
30일 전: 103
전체 시간: 5,513
