소개
Battery degradation or damage can lead to the device not charging or not holding a charge. This guide shows how to replace the battery within the Lenovo V14-IIL laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Lenovo V14-IIL troubleshooting page to review if there may be a solution that does not require component replacement.
Ensure your charging brick and cable are functional and properly plugged in; if these steps work, you will not need to replace the battery.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
필요한 것
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
