주요 콘텐츠로 건너뛰기
Lenovo Yoga 2 13" Battery Replacement
필요한 것
  1. Lenovo Yoga 2 13" Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Battery Replacement: 2 단계, 이미지 1/1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Locate the battery of the laptop.
  4. Lenovo Yoga 2 13" Battery Replacement: 4 단계, 이미지 1/1
    • To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
  5. Lenovo Yoga 2 13" Battery Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery from the laptop by pulling the power connector towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Yoga 2 13" Battery Replacement: 6 단계, 이미지 1/1
    • Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Nichelle
회원 가입일: 03/11/15
1,550 평판
안내서 5개 작성하였습니다
Marist, Team 1-2, Laflen Spring 2015 Marist, Team 1-2, Laflen Spring 2015 회원
MARS-LAFLEN-S15S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 42
전체 시간: 31,786
