주요 콘텐츠로 건너뛰기
Lenovo Yoga 710-11ISK Hinge Replacement
필요한 것
  1. Lenovo Yoga 710-11ISK Hinge Replacement, Hinge: 1 단계, 이미지 1/1
    • Remove the eleven screws that secure the bottom panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Hinge Replacement: 2 단계, 이미지 1/1
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Hinge Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the ten black screws on the two hinge brackets.
  4. Lenovo Yoga 710-11ISK Hinge Replacement: 4 단계, 이미지 1/3 Lenovo Yoga 710-11ISK Hinge Replacement: 4 단계, 이미지 2/3 Lenovo Yoga 710-11ISK Hinge Replacement: 4 단계, 이미지 3/3
    • Wedge an opening tool between the display and display housing, then slide the opening tool around the perimeter of the display while gently prying until the display releases.
    • Remove the screw covers located near the hinges on the display side using an opening tool.
    • Remove the cover panel between the screw covers using an opening tool.
  5. Lenovo Yoga 710-11ISK Hinge Replacement: 5 단계, 이미지 1/1
    • Remove the screws securing the hinge brackets with a Phillips #000 screwdriver.
    • Remove the plastic cover that holds the wires in place.
  6. Lenovo Yoga 710-11ISK Hinge Replacement: 6 단계, 이미지 1/3 Lenovo Yoga 710-11ISK Hinge Replacement: 6 단계, 이미지 2/3 Lenovo Yoga 710-11ISK Hinge Replacement: 6 단계, 이미지 3/3
    • Disconnect the black and white wires from the sides of the display.
    • Disconnect the orange ribbon cable.
    • Remove the tape, covers, and stickers that hold in the components.
  7. Lenovo Yoga 710-11ISK Hinge Replacement: 7 단계, 이미지 1/2 Lenovo Yoga 710-11ISK Hinge Replacement: 7 단계, 이미지 2/2
    • Soldering/desoldering presents potential for device damage and burns. Always solder/desolder in a well-ventilated environment.
    • Use a soldering iron to disconnect the ends of both wires that are embedded into the display.
    • Remove the hinges and their components from the computer.
결론
Jarrett Stoll
회원 가입일: 02/10/22
385 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 35
전체 시간: 891
