주요 콘텐츠로 건너뛰기
Lenovo Yoga 720-15IKB Fan Replacement
필요한 것
  1. Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: 1 단계, 이미지 1/3 Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: 1 단계, 이미지 2/3 Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Fan Replacement: 2 단계, 이미지 1/2 Lenovo Yoga 720-15IKB Fan Replacement: 2 단계, 이미지 2/2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Fan Replacement, Fan: 3 단계, 이미지 1/2 Lenovo Yoga 720-15IKB Fan Replacement, Fan: 3 단계, 이미지 2/2
    • Remove the six 5.2mm Torx T5 screws holding the fan in place.
    • Remove the five 5.0mm Torx T5 screws holding the fan in place.
  4. Lenovo Yoga 720-15IKB Fan Replacement: 4 단계, 이미지 1/3 Lenovo Yoga 720-15IKB Fan Replacement: 4 단계, 이미지 2/3 Lenovo Yoga 720-15IKB Fan Replacement: 4 단계, 이미지 3/3
    • Disconnect the two fan wire connectors.
    • Firmly pull the connector out horizontally away from the socket.
    • Carefully lift the fan up and out.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Shaina Bagri
회원 가입일: 01/23/20
375 평판
안내서 2개 작성하였습니다
Cal Poly, Team S19-G3, White Winter 2020 Cal Poly, Team S19-G3, White Winter 2020 회원
CPSU-WHITE-W20S19G3
4 회원들
안내서 22개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 62
전체 시간: 2,701
