소개
This guide will show you how to remove the charging port on the 13 inch Lenovo Yoga 900 (900-13ISK). Luckily, this component is completely modular, so you can replace it without sourcing a new motherboard or daughterboard. If your computer does not charge, or if your computer fails to turn on and you have already ruled out a faulty battery as the cause, replacing the charging port should fix the issue.
Be sure to unplug and completely turn off your device before you start working.
필요한 것
Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
Use a Phillips #00 screwdriver to remove the 2.7 mm screw that is holding down the SSD card.
Pry up the gray and black coaxial cables from the Wi-Fi card using a spudger.
Move the cables to the side.
이 단계에 사용된 도구:Tweezers$4.99
Using the pointed end of a spudger, flip up the hinged locking tabs of the eight ZIF connectors on the motherboard.
Pull the eight cables out from their connectors using a pair of blunt nose tweezers.
Remove the two 3.5 mm screws from the charging port with a Phillips #00 screwdriver.
댓글 2개
Bruh, why don't you show how to reconnect the charging port? That's what I am stuck on. It looked easy and now I can't get it back in.
