소개
If the control panel on your Levoit LV-H132 device is not working when it's connected to the power outlet, then it is time to replace the motherboard. Is the device overheating, producing strange noises, or smell burnt? Then the motherboard must have short circuited. Other causes could be that it has gone bad or gone old.
필요한 것
Remove two 6 mm screws that hold the motherboard in place with a Phillips #1 screwdriver.
That's all well and good but how do you get the motherboard? levoit won't sell the part!
John Christiano
standchen511312@gmail.com
다른 2명이 해당 안내서를 완성하였습니다.
