주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LexiBook Tablet One Battery Replacement
필요한 것
  1. LexiBook Tablet One Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 LexiBook Tablet One Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 LexiBook Tablet One Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • First the case must be opened. Insert the blue plastic opening tool where the two casings meet. Pry up until you hear a clip pop and then carefully move around the device. Do this until the front and back casing are completely separate from one another.
    • You will again need to be careful opening the device in order to avoid damaging the speaker, or worse, the motherboard.
    • The clips holding the case together are roughly 1.5 in. apart.
  2. LexiBook Tablet One Battery Replacement: 2 단계, 이미지 2개 중 1개 LexiBook Tablet One Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully remove the speaker by inserting the spudger between the case and the speaker. Pry upwards until the speaker comes out. Set the speaker to the side.
    • Be careful with the speaker wires. The wires can easily detach from both the speaker and the board.
  3. LexiBook Tablet One Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use the spudger to repeatedly gouge between the battery and LCD. Work around the battery until it breaks free.
    • It may feel as though you are pushing extremely hard. This is normal as the adhesive is quite strong. As long as you don't tip the tool you use and puncture the battery / LCD it will be fine.
  4. LexiBook Tablet One Battery Replacement: 4 단계, 이미지 2개 중 1개 LexiBook Tablet One Battery Replacement: 4 단계, 이미지 2개 중 2개
    • The tape around the battery's circuit board is extremely thorough. There are 2 pieces of tape, on folded over the side and another wrapped around the circuit board. Simply peel both off.
  5. LexiBook Tablet One Battery Replacement: 5 단계, 이미지 2개 중 1개 LexiBook Tablet One Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Now that the battery is pry'd free and the tape is removed, the wires should be able to move freely. Give yourself as much room as you need, and solder off the connections on the motherboard.
    • How to Solder is iFixit's official guide to use a soldering gun.
결론
작성자
4다른 기여자 명과 함께
Jordan
회원 가입일: 03/11/15
650 평판
안내서 4개를 작성함
Colorado Springs, Team 2-5, Panko Spring 2015 Colorado Springs, Team 2-5, Panko Spring 2015 회원
UCCS-PANKO-S15S2G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 40
전체 시간: 1,912
