주요 콘텐츠로 건너뛰기
LexiBook Tablet One Speaker Replacement
필요한 것
  1. LexiBook Tablet One Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 1개 LexiBook Tablet One Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 2개 LexiBook Tablet One Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 3개
    • Insert the blue plastic opening tool where the case has a seam. Move side to side until you hear a clip pop. Move around the edge of the case until all clips are separated. The clips are 1.5 in. apart within the case.
  2. LexiBook Tablet One Speaker Replacement: 2 단계, 이미지 2개 중 1개 LexiBook Tablet One Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside.
  3. LexiBook Tablet One Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Using a soldering gun, apply heat where the speaker wires meet the motherboard. Heat the solder around both the black and red wires until they easily slide away.
    • Be careful not to heat the motherboard too long so to avoid damaging other components. Also, care to avoid liquefying the solder on any near by components.
    • How to Solder is IFixIt's official guide to use a soldering gun.
결론
작성자
3다른 기여자 명과 함께
Jordan
회원 가입일: 03/11/15
650 평판
안내서 4개를 작성함
Colorado Springs, Team 2-5, Panko Spring 2015 Colorado Springs, Team 2-5, Panko Spring 2015 회원
UCCS-PANKO-S15S2G5
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 152
