주요 콘텐츠로 건너뛰기
Lighting: Replacing Light Emitting Diode
필요한 것
  1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: 1 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, remove the base of the Light Angel.
    • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
  2. Lighting: Replacing Light Emitting Diode: 2 단계, 이미지 1개 중 1개
    • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
    • To remove the screw, turn counterclockwise.
    • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
  3. Lighting: Replacing Light Emitting Diode: 3 단계, 이미지 1개 중 1개
    • Remove and set aside the (4) AA batteries in the battery housing.
  4. Lighting: Replacing Light Emitting Diode: 4 단계, 이미지 1개 중 1개
    • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
    • To remove the screws, turn counterclockwise.
  5. Lighting: Replacing Light Emitting Diode: 5 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
  6. Lighting: Replacing Light Emitting Diode: 6 단계, 이미지 1개 중 1개
    • Locate the faulty light emitting diode on the back of the circuit board.
    • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
    • Do not allow the soldering iron to come in contact with other components on the circuit board.
    • For detailed instructions on how to solder go to 연결부 납땜 및 납제거 방법
  7. Lighting: Replacing Light Emitting Diode: 7 단계, 이미지 1개 중 1개
    • Insert the new light emitting diode through the two holes left from removing the old one.
    • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: 연결부 납땜 및 납제거 방법
  8. Lighting: Replacing Light Emitting Diode: 8 단계, 이미지 1개 중 1개
    • Using solder and a soldering iron, solder the new LED to the circuit board.
    • Keep your solder joints separate to avoid short circuiting the circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Matthew Corigliano
회원 가입일: 02/10/16
155 평판
안내서 1개를 작성함
Colorado Springs, Team 8-6, Mcmichael Spring 2016 Colorado Springs, Team 8-6, Mcmichael Spring 2016 회원
UCCS-MCMICHAEL-S16S8G6
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 82
전체 시간: 6,107
