주요 콘텐츠로 건너뛰기
Linksys EA9200 Antenna Port Replacement
필요한 것
  1. Linksys EA9200 Antenna Port  Replacement, Linksys EA9200 Disassembly: 1 단계, 이미지 1/2 Linksys EA9200 Antenna Port  Replacement, Linksys EA9200 Disassembly: 1 단계, 이미지 2/2
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 Antenna Port  Replacement: 2 단계, 이미지 1/2 Linksys EA9200 Antenna Port  Replacement: 2 단계, 이미지 2/2
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 Antenna Port  Replacement: 3 단계, 이미지 1/3 Linksys EA9200 Antenna Port  Replacement: 3 단계, 이미지 2/3 Linksys EA9200 Antenna Port  Replacement: 3 단계, 이미지 3/3
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 Antenna Port  Replacement: 4 단계, 이미지 1/3 Linksys EA9200 Antenna Port  Replacement: 4 단계, 이미지 2/3 Linksys EA9200 Antenna Port  Replacement: 4 단계, 이미지 3/3
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 Antenna Port  Replacement: 5 단계, 이미지 1/3 Linksys EA9200 Antenna Port  Replacement: 5 단계, 이미지 2/3 Linksys EA9200 Antenna Port  Replacement: 5 단계, 이미지 3/3
    • Lift the board and pull down, away from the antennas.
  6. Linksys EA9200 Antenna Port  Replacement, Antenna Port: 6 단계, 이미지 1/2 Linksys EA9200 Antenna Port  Replacement, Antenna Port: 6 단계, 이미지 2/2
    • The antenna ports are connected to the board with a wire that has a "snap" connector.
  7. Linksys EA9200 Antenna Port  Replacement: 7 단계, 이미지 1/2 Linksys EA9200 Antenna Port  Replacement: 7 단계, 이미지 2/2
    • Desolder the four pins of the antenna port.
    • Do not place the soldering iron on the wrong terminals as this can cause the device to no longer to function.
    • How To Solder and Desolder Connections is iFixit's official guide on how to use a soldering iron
    • You will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
    • Temperature of the component will be very hot when desoldered, take precaution when handling.
  8. Linksys EA9200 Antenna Port  Replacement: 8 단계, 이미지 1/1
    • Once the solder is melted, quickly pull broken antenna port.
결론
Shane Davis
회원 가입일: 10/05/16
374 평판
안내서 3개 작성하였습니다
USF Tampa, Team 9-1, Lacy Fall 2016 USF Tampa, Team 9-1, Lacy Fall 2016 회원
USFT-LACY-F16S9G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 805
