주요 콘텐츠로 건너뛰기
Linksys WAP54g Bottom Casing/Motherboard Replacement
필요한 것
  1. Linksys WAP54g Bottom Casing/Motherboard Replacement, Top Casing: 1 단계, 이미지 1/1
    • Power down and unplug the device.
  2. Linksys WAP54g Bottom Casing/Motherboard Replacement: 2 단계, 이미지 1/1
  3. Linksys WAP54g Bottom Casing/Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Bottom Casing/Motherboard Replacement: 4 단계, 이미지 1/1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Bottom Casing/Motherboard Replacement: 5 단계, 이미지 1/1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Bottom Casing/Motherboard Replacement: 6 단계, 이미지 1/1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Bottom Casing/Motherboard Replacement: 7 단계, 이미지 1/2 Linksys WAP54g Bottom Casing/Motherboard Replacement: 7 단계, 이미지 2/2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Bottom Casing/Motherboard Replacement: 8 단계, 이미지 1/2 Linksys WAP54g Bottom Casing/Motherboard Replacement: 8 단계, 이미지 2/2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: 9 단계, 이미지 1/2 Linksys WAP54g Bottom Casing/Motherboard Replacement, Bottom Casing/Motherboard: 9 단계, 이미지 2/2
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
결론
After the motherboard is isolated component level repairs can be made.
다른 2명이 해당 안내서를 완성하였습니다.
Mathew Fuller
회원 가입일: 10/04/11
146 평판
안내서 1개 작성함
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 회원
CPSU-MANESS-F11S21G21
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 2,593
