주요 콘텐츠로 건너뛰기
Linksys WAP54g Top Casing Replacement
필요한 것
  1. Linksys WAP54g Top Casing Replacement, Top Casing: 1 단계, 이미지 1/1
    • Power down and unplug the device.
  2. Linksys WAP54g Top Casing Replacement: 2 단계, 이미지 1/1
  3. Linksys WAP54g Top Casing Replacement: 3 단계, 이미지 1/1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Top Casing Replacement: 4 단계, 이미지 1/1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Top Casing Replacement: 5 단계, 이미지 1/1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Top Casing Replacement: 6 단계, 이미지 1/1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Top Casing Replacement: 7 단계, 이미지 1/2 Linksys WAP54g Top Casing Replacement: 7 단계, 이미지 2/2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Top Casing Replacement: 8 단계, 이미지 1/2 Linksys WAP54g Top Casing Replacement: 8 단계, 이미지 2/2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
결론
From here you can take apart the rest of the router apart by following subsequent guides.
다른 한 분이 해당 안내서를 완성하였습니다.
Derek Myers
회원 가입일: 10/04/11
288 평판
안내서 5개 작성하였습니다
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 회원
CPSU-MANESS-F11S21G21
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
Bon Tutoriel. Simple, mais les plastiques sont solidement attacher. Il faut donc forcer pour démonter la partie bleu. Mais c’est possible.
Merci.
Philippe Gabriel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,526
