소개
Antennas transmit the wireless internet. Sometimes they break and need to be replaced.
If, after reading through this guide, you are still in need of assistance, please refer back to the device page or the troubleshooting page.
도구
도구는 필요하지 않습니다.
  1. Unfold the antennas straight away from the device.
    • Unfold the antennas straight away from the device.
  2. Remove the black caps from the antennas by pulling them away from the device. Remove the black caps from the antennas by pulling them away from the device. Remove the black caps from the antennas by pulling them away from the device.
    • Remove the black caps from the antennas by pulling them away from the device.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Unscrew each of the antennas from the wireless device. Unscrew each of the antennas from the wireless device. Unscrew each of the antennas from the wireless device.
    • Unscrew each of the antennas from the wireless device.
  5. Once the old antennas are removed, replace them with them with the new ones by screwing them on the device. Once the old antennas are removed, replace them with them with the new ones by screwing them on the device.
    • Once the old antennas are removed, replace them with them with the new ones by screwing them on the device.
결론
Aaron Brown
회원 가입일: 2011년 10월 11일
163 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-7, Regan Fall 2011 Cal Poly, Team 17-7, Regan Fall 2011 회원
CPSU-REGAN-F11S17G7
4 회원들
안내서 4개 작성하였습니다
I have a wrt54gs and the antennas are plastic crap with no cuff to unscrew. They are fastened in by "body snaps" like most of the cheap crap that's made in china. Off to find instructions for router disassembly. Just thought you should know this won't necessarily work for the models listed.
Ed Rutmayer - 답글
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 4,477
