주요 콘텐츠로 건너뛰기
Linksys WRT54G Antennas Replacement
필요한 것
  1. Linksys WRT54G Antennas Replacement, Antennas: 1 단계, 이미지 1/1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Antennas Replacement: 2 단계, 이미지 1/3 Linksys WRT54G Antennas Replacement: 2 단계, 이미지 2/3 Linksys WRT54G Antennas Replacement: 2 단계, 이미지 3/3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Antennas Replacement: 3 단계, 이미지 1/3 Linksys WRT54G Antennas Replacement: 3 단계, 이미지 2/3 Linksys WRT54G Antennas Replacement: 3 단계, 이미지 3/3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Antennas Replacement, Antennas: 4 단계, 이미지 1/2 Linksys WRT54G Antennas Replacement, Antennas: 4 단계, 이미지 2/2
    • Once the old antennas are removed, replace them with them with the new ones by screwing them on the device.
결론
Aaron Brown
회원 가입일: 10/11/11
163 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-7, Regan Fall 2011 Cal Poly, Team 17-7, Regan Fall 2011 회원
CPSU-REGAN-F11S17G7
4 회원들
안내서 4개 작성하였습니다
댓글 2개
I have a wrt54gs and the antennas are plastic crap with no cuff to unscrew. They are fastened in by "body snaps" like most of the cheap crap that's made in china. Off to find instructions for router disassembly. Just thought you should know this won't necessarily work for the models listed.
Ed Rutmayer - 답글
Most do not have removeable antennaes
tom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 5,764
