주요 콘텐츠로 건너뛰기
Logitech Dual Action disassembly
필요한 것
  1. Logitech Dual Action disassembly, Taking out the screws: 1 단계, 이미지 1개 중 1개
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
  2. Logitech Dual Action disassembly, Opening the controller: 2 단계, 이미지 3개 중 1개 Logitech Dual Action disassembly, Opening the controller: 2 단계, 이미지 3개 중 2개 Logitech Dual Action disassembly, Opening the controller: 2 단계, 이미지 3개 중 3개
    • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
    • Separate the top and bottom casing.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
  3. Logitech Dual Action disassembly, Cleaning the buttons: 3 단계, 이미지 1개 중 1개
    • Turn the top casing of the controller over to remove all the buttons.
    • Wipe each individual button with a piece of cloth and rubbing alcohol.
결승점
다른 10명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Brian Neuman
회원 가입일: 01/20/15
968 평판
안내서 3개를 작성함
USF Tampa, Team 7-4, Remmell Winter 2015 USF Tampa, Team 7-4, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G4
4 회원들
안내서 5개를 작성함
댓글 한 개
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 34
지난 30일: 90
전체 시간: 7,075
