소개
Follow this guide to remove or replace the mouse feet (also called skates or pads) on a Logitech G PRO Wireless mouse.
If you plan to reuse the mouse feet, you’ll need to apply heat to loosen the adhesive and remove the feet with minimal bending. Bent or torn mouse feet may require replacement feet.
필요한 것
Shift the power switch down to turn off your mouse (when the PRO Wireless label is oriented right-side up).
Heat an iOpener and apply it to the upper mouse foot for one minute.
Insert the flat end of a spudger under the upper mouse foot.
Slide the spudger under the length of the upper mouse foot to cut through the adhesive and detach it from the mouse.
Apply the iOpener to the lower mouse feet for one minute.
Insert the flat end of a spudger under the left lower mouse foot.
