주요 콘텐츠로 건너뛰기
Logitech G915 TKL Keyswitch Replacement
필요한 것
  1. Logitech G915 TKL Keyswitch Replacement, Keyswitch: 1 단계, 이미지 2개 중 1개 Logitech G915 TKL Keyswitch Replacement, Keyswitch: 1 단계, 이미지 2개 중 2개
    • Remove all of the keycaps on the keyboard.
    • Unscrew the 2mm #00 Phillips screws circled in the picture provided.
  2. Logitech G915 TKL Keyswitch Replacement: 2 단계, 이미지 2개 중 1개 Logitech G915 TKL Keyswitch Replacement: 2 단계, 이미지 2개 중 2개
    • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
    • Unscrew the two 2.5mm #0 Phillips screws circled in the picture provided.
    • Remove the backplate by grabbing the notch to the right and pulling up.
  3. Logitech G915 TKL Keyswitch Replacement: 3 단계, 이미지 2개 중 1개 Logitech G915 TKL Keyswitch Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the foam strips shown in the picture provided.
    • Unscrew all the 2mm #00 Phillips screws on the back of the keyboard circled in the picture provided.
  4. Logitech G915 TKL Keyswitch Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the casing on the keyboard to reveal the motherboard.
  5. Logitech G915 TKL Keyswitch Replacement: 5 단계, 이미지 1개 중 1개
    • Find the corresponding soldering point for the keyswitch you wish to replace.
  6. Logitech G915 TKL Keyswitch Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully heat the soldering wire.
    • Place the wire near the keyswitch's solder points so that it can be desoldered by the wire.
    • Insert your new keyswitch in place of the old one.
    • Solder the new keyswitch into place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ethan Bedard
회원 가입일: 03/13/23
587 평판
안내서 3개를 작성함
UMass Dartmouth, Team 3-6, Petersen Spring 2023 UMass Dartmouth, Team 3-6, Petersen Spring 2023 회원
UMASSD-PETERSEN-S23S3G6
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 38
지난 7일: 243
지난 30일: 892
전체 시간: 21,982
