주요 콘텐츠로 건너뛰기
Logitech Harmony Smart Control Charging Port Replacement
필요한 것
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: 1 단계, 이미지 1/2 Logitech Harmony Smart Control Charging Port Replacement, Charging Port: 1 단계, 이미지 2/2
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: 2 단계, 이미지 1/2 Logitech Harmony Smart Control Charging Port Replacement: 2 단계, 이미지 2/2
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: 3 단계, 이미지 1/2 Logitech Harmony Smart Control Charging Port Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: 4 단계, 이미지 1/2 Logitech Harmony Smart Control Charging Port Replacement: 4 단계, 이미지 2/2
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: 5 단계, 이미지 1/3 Logitech Harmony Smart Control Charging Port Replacement: 5 단계, 이미지 2/3 Logitech Harmony Smart Control Charging Port Replacement: 5 단계, 이미지 3/3
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: 6 단계, 이미지 1/3 Logitech Harmony Smart Control Charging Port Replacement: 6 단계, 이미지 2/3 Logitech Harmony Smart Control Charging Port Replacement: 6 단계, 이미지 3/3
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Josh Hendricks
회원 가입일: 09/17/15
464 평판
안내서 4개 작성하였습니다
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 710
