주요 콘텐츠로 건너뛰기
Logitech Harmony Smart Control Charging Port Replacement
필요한 것
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: 2 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Charging Port Replacement: 2 단계, 이미지 2개 중 2개
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: 3 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: 4 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Charging Port Replacement: 4 단계, 이미지 2개 중 2개
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: 5 단계, 이미지 3개 중 1개 Logitech Harmony Smart Control Charging Port Replacement: 5 단계, 이미지 3개 중 2개 Logitech Harmony Smart Control Charging Port Replacement: 5 단계, 이미지 3개 중 3개
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: 6 단계, 이미지 3개 중 1개 Logitech Harmony Smart Control Charging Port Replacement: 6 단계, 이미지 3개 중 2개 Logitech Harmony Smart Control Charging Port Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Josh Hendricks
회원 가입일: 09/17/15
464 평판
안내서 4개를 작성함
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 860
