주요 콘텐츠로 건너뛰기
Logitech Harmony Smart Control Hub Light Bulb Replacement
필요한 것
  1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: 1 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: 1 단계, 이미지 2개 중 2개
    • Use a spudger to lift up one of the rubber pads on the bottom of the hub.
    • Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
    • Repeat for the second rubber pad.
  2. Logitech Harmony Smart Control Hub Light Bulb Replacement: 2 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Hub Light Bulb Replacement: 2 단계, 이미지 2개 중 2개
    • Use a PH00 screwdriver bit to remove the four 6mm Phillips screws on the bottom of the device.
  3. Logitech Harmony Smart Control Hub Light Bulb Replacement: 3 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Hub Light Bulb Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to separate the top and bottom pieces of the device.
  4. Logitech Harmony Smart Control Hub Light Bulb Replacement: 4 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Hub Light Bulb Replacement: 4 단계, 이미지 2개 중 2개
    • Use the PH00 screwdriver bit to unscrew the three 4mm Phillips screws on the control board.
  5. Logitech Harmony Smart Control Hub Light Bulb Replacement: 5 단계, 이미지 2개 중 1개 Logitech Harmony Smart Control Hub Light Bulb Replacement: 5 단계, 이미지 2개 중 2개
    • Place the end of the opening tool under the yellow corner of the circuit board as shown.
    • Gently push upward to pry the board from its housing.
  6. Logitech Harmony Smart Control Hub Light Bulb Replacement: 6 단계, 이미지 3개 중 1개 Logitech Harmony Smart Control Hub Light Bulb Replacement: 6 단계, 이미지 3개 중 2개 Logitech Harmony Smart Control Hub Light Bulb Replacement: 6 단계, 이미지 3개 중 3개
    • Determine which of the five bulbs are defective.
    • Turn the board over to expose the bulb solder.
    • Using a soldering iron, remove the solder and bulb. Replace with a new bulb and re-solder.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Josh Hendricks
회원 가입일: 09/17/15
464 평판
안내서 4개를 작성함
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 9
전체 시간: 657
