주요 콘텐츠로 건너뛰기
Logitech Harmony Smart Control Reset Button Replacement
필요한 것
  1. Logitech Harmony Smart Control Reset Button Replacement, Reset Button: 1 단계, 이미지 1/2 Logitech Harmony Smart Control Reset Button Replacement, Reset Button: 1 단계, 이미지 2/2
    • Using a plastic opening tool, lift up the rubber pad.
    • From the bottom of the device, with your fingers, pull back the rubber pad. This will expose the screw holes.
    • On the bottom of the hub, repeat the step above for the second rubber pad.
  2. Logitech Harmony Smart Control Reset Button Replacement: 2 단계, 이미지 1/2 Logitech Harmony Smart Control Reset Button Replacement: 2 단계, 이미지 2/2
    • With the PH00 bit, remove the four 6mm Phillips screws.
  3. Logitech Harmony Smart Control Reset Button Replacement: 3 단계, 이미지 1/2 Logitech Harmony Smart Control Reset Button Replacement: 3 단계, 이미지 2/2
    • With the plastic opening tool, separate the pieces of plastic from each other
  4. Logitech Harmony Smart Control Reset Button Replacement: 4 단계, 이미지 1/2 Logitech Harmony Smart Control Reset Button Replacement: 4 단계, 이미지 2/2
    • With the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Reset Button Replacement: 5 단계, 이미지 1/3 Logitech Harmony Smart Control Reset Button Replacement: 5 단계, 이미지 2/3 Logitech Harmony Smart Control Reset Button Replacement: 5 단계, 이미지 3/3
    • From the yellow corner, pry the circuit board from the housing..
  6. Logitech Harmony Smart Control Reset Button Replacement: 6 단계, 이미지 1/3 Logitech Harmony Smart Control Reset Button Replacement: 6 단계, 이미지 2/3 Logitech Harmony Smart Control Reset Button Replacement: 6 단계, 이미지 3/3
    • Locate the defective reset button.
    • Turn the board around to expose the reset solder.
    • Using soldering iron, remove solder and reset button. Replace reset button and solder.
결론
Zachary Robinson
회원 가입일: 09/17/15
126 평판
안내서 1개 작성함
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 957
