소개
Use this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech MX Anywhere 3.
While it’s possible to cleanly remove the feet, you may need replacements if one rips or separates from its adhesive pad.
필요한 것
Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
Heat an iOpener and apply it to the mouse feet for about two minutes.
There are small gaps in the rims surrounding each foot. This is where to place the tool in the next step.
Push the tip of an opening pick underneath the mouse foot adhesive, into the gap in the rim.
Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
Repeat to remove the three remaining mouse feet.
Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
Peel your new mouse feet away from their adhesive liners and press them firmly into place.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
다른 한 분이 해당 안내서를 완성하였습니다.
