주요 콘텐츠로 건너뛰기
Logitech MX Master 3 Mouse Feet Replacement
필요한 것
  1. Logitech MX Master 3 Mouse Feet Replacement, Soften the mouse feet adhesive: 1 단계, 이미지 1/3 Logitech MX Master 3 Mouse Feet Replacement, Soften the mouse feet adhesive: 1 단계, 이미지 2/3 Logitech MX Master 3 Mouse Feet Replacement, Soften the mouse feet adhesive: 1 단계, 이미지 3/3
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master 3 Mouse Feet Replacement, Separate the mouse foot adhesive: 2 단계, 이미지 1/3 Logitech MX Master 3 Mouse Feet Replacement, Separate the mouse foot adhesive: 2 단계, 이미지 2/3 Logitech MX Master 3 Mouse Feet Replacement, Separate the mouse foot adhesive: 2 단계, 이미지 3/3
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. Logitech MX Master 3 Mouse Feet Replacement, Remove the right and rear mouse feet: 3 단계, 이미지 1/2 Logitech MX Master 3 Mouse Feet Replacement, Remove the right and rear mouse feet: 3 단계, 이미지 2/2
    • Repeat the previous two steps to remove the right and the rear mouse feet.
  4. Logitech MX Master 3 Mouse Feet Replacement, Reassembly information: 4 단계, 이미지 1/3 Logitech MX Master 3 Mouse Feet Replacement, Reassembly information: 4 단계, 이미지 2/3 Logitech MX Master 3 Mouse Feet Replacement, Reassembly information: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  5. Logitech MX Master 3 Mouse Feet Replacement, Remove the front mouse foot: 5 단계, 이미지 1/1
    • Remove the front mouse foot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
197,118 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 63
30일 전: 282
전체 시간: 8,047
