주요 콘텐츠로 건너뛰기
Logitech MX Vertical Feet Replacement
필요한 것
  1. Logitech MX Vertical Feet Replacement, Turn off the mouse: 1 단계, 이미지 1/1
    • Before you begin, flip the mouse's power switch into the OFF position.
  2. Logitech MX Vertical Feet Replacement, Lay the mouse buttons-side down: 2 단계, 이미지 1/1
    • The mouse's unique shape prevents it from laying flat. If you need to, lay it button-side down onto a soft towel to prevent wobble.
  3. Logitech MX Vertical Feet Replacement, Heat the feet adhesive: 3 단계, 이미지 1/2 Logitech MX Vertical Feet Replacement, Heat the feet adhesive: 3 단계, 이미지 2/2
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the feet on the mouse's underside for about two minutes.
    • Alternatively, a hair dryer or a heat gun may also be used, but be careful not to overheat the mouse.
  4. Logitech MX Vertical Feet Replacement, Remove the mouse feet: 4 단계, 이미지 1/3 Logitech MX Vertical Feet Replacement, Remove the mouse feet: 4 단계, 이미지 2/3 Logitech MX Vertical Feet Replacement, Remove the mouse feet: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Insert one arm of a pair of sharp tweezers underneath the end of one foot.
    • Grip the foot and begin to peel it away from the bottom of the mouse.
    • Peel slowly, making sure the foot and its adhesive are removed in one piece.
    • The foot should come away from the mouse without the need for much force. If it feels stuck, apply more heat and try again.
  5. Logitech MX Vertical Feet Replacement: 5 단계, 이미지 1/3 Logitech MX Vertical Feet Replacement: 5 단계, 이미지 2/3 Logitech MX Vertical Feet Replacement: 5 단계, 이미지 3/3
    • Use a pair of tweezers to peel the foot away from the mouse to completely remove it.
    • Place the foot adhesive-side up on a clean surface.
  6. Logitech MX Vertical Feet Replacement: 6 단계, 이미지 1/3 Logitech MX Vertical Feet Replacement: 6 단계, 이미지 2/3 Logitech MX Vertical Feet Replacement: 6 단계, 이미지 3/3
    • Insert a tweezer arm underneath the end of the second foot.
    • Peel the foot away from the mouse to completely remove it.
    • The foot should come away from the mouse without much force. If it feels stuck, apply more heat and try again.
    • During reassembly, remove any leftover adhesive before installing new feet.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Carsten Frauenheim
회원 가입일: 03/10/20
119,024 평판
안내서 341개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,103개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 20
30일 전: 104
전체 시간: 2,839
