주요 콘텐츠로 건너뛰기
Logitech Signature Slim Solar+ Feet Replacement
필요한 것
  1. Logitech Signature Slim Solar+ Feet Replacement, Prepare your keyboard for disassembly: 1 단계, 이미지 2개 중 1개 Logitech Signature Slim Solar+ Feet Replacement, Prepare your keyboard for disassembly: 1 단계, 이미지 2개 중 2개
    • Slide the keyboard's power switch into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface may scratch the keyboard, place a soft towel under it.
  2. Logitech Signature Slim Solar+ Feet Replacement: 2 단계, 이미지 3개 중 1개 Logitech Signature Slim Solar+ Feet Replacement: 2 단계, 이미지 3개 중 2개 Logitech Signature Slim Solar+ Feet Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the point of a spudger under an end of the foot.
    • Slide the spudger underneath the foot and lift until you can grip it with your fingers.
    • Peel the foot up and remove it.
  3. Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: 3 단계, 이미지 3개 중 1개 Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: 3 단계, 이미지 3개 중 2개 Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: 3 단계, 이미지 3개 중 3개
    • Remove a replacement foot from its backing and firmly press it into place.
결론
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
작성자
2다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
309,568 평판
안내서 701개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 26
전체 시간: 110
