주요 콘텐츠로 건너뛰기
Logitech UE Boombox Tweeter Speaker Replacement
필요한 것
  1. Logitech UE Boombox Tweeter Speaker Replacement, Speaker Grille: 1 단계, 이미지 2개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement, Speaker Grille: 1 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry open the power button cover.
    • Once the power button cover is slightly opened, use your fingers to remove the power button cover.
  2. Logitech UE Boombox Tweeter Speaker Replacement: 2 단계, 이미지 3개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 2 단계, 이미지 3개 중 2개 Logitech UE Boombox Tweeter Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Press firmly on the end of the latch and pull the two-wire connector away from the base to separate.
  3. Logitech UE Boombox Tweeter Speaker Replacement: 3 단계, 이미지 3개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 3 단계, 이미지 3개 중 2개 Logitech UE Boombox Tweeter Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
  4. Logitech UE Boombox Tweeter Speaker Replacement: 4 단계, 이미지 3개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 4 단계, 이미지 3개 중 2개 Logitech UE Boombox Tweeter Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Lightly, pry up on each side of the black band connector lock using your fingertips.
    • Once unlocked, pull straight up on the connector to remove.
  5. Logitech UE Boombox Tweeter Speaker Replacement: 5 단계, 이미지 2개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the five black 14mm Phillips #2 screws from the black plastic side panel.
    • Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the black plastic screw panel from the boombox.
  6. Logitech UE Boombox Tweeter Speaker Replacement: 6 단계, 이미지 2개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • On the opposite side of the device, pry open the volume rocker with a metal spudger.
    • Remove the panel with your fingers once the volume rocker is slightly opened.
  7. Logitech UE Boombox Tweeter Speaker Replacement: 7 단계, 이미지 3개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 7 단계, 이미지 3개 중 2개 Logitech UE Boombox Tweeter Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the one silver16 mm Phillips #2 screw from the black plastic side panel.
    • Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
  8. Logitech UE Boombox Tweeter Speaker Replacement: 8 단계, 이미지 2개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Firmly press on the end of the latch and pull the two-wire connector away from the base.
  9. Logitech UE Boombox Tweeter Speaker Replacement: 9 단계, 이미지 2개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 9 단계, 이미지 2개 중 2개
    • Pull up on the aluminum boombox handle to remove.
  10. Logitech UE Boombox Tweeter Speaker Replacement: 10 단계, 이미지 2개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 10 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry the rubber base apart from the aluminum grille.
  11. Logitech UE Boombox Tweeter Speaker Replacement: 11 단계, 이미지 2개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 11 단계, 이미지 2개 중 2개
    • Pull the rubber base away from the boombox.
  12. Logitech UE Boombox Tweeter Speaker Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • There should be a total of eight screws removed in this step.
  13. Logitech UE Boombox Tweeter Speaker Replacement: 13 단계, 이미지 3개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 13 단계, 이미지 3개 중 2개 Logitech UE Boombox Tweeter Speaker Replacement: 13 단계, 이미지 3개 중 3개
    • Pull vertically on the speaker grille to remove it from the boombox.
  14. Logitech UE Boombox Tweeter Speaker Replacement, Tweeter Speaker: 14 단계, 이미지 3개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement, Tweeter Speaker: 14 단계, 이미지 3개 중 2개 Logitech UE Boombox Tweeter Speaker Replacement, Tweeter Speaker: 14 단계, 이미지 3개 중 3개
    • Remove the fifteen 13.0 mm Phillips #2 screws from the side of the device containing two speakers.
    • Separate the two halves by gently pulling them apart.
  15. Logitech UE Boombox Tweeter Speaker Replacement: 15 단계, 이미지 1개 중 1개
    • Locate the two tweeter speakers.
    • One tweeter speaker is adjacent to primary speaker and the other is below the motherboard.
  16. Logitech UE Boombox Tweeter Speaker Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the two 7.0 mm screws Phillips #2.
  17. Logitech UE Boombox Tweeter Speaker Replacement: 17 단계, 이미지 2개 중 1개 Logitech UE Boombox Tweeter Speaker Replacement: 17 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using flat-head Tweezers lift tweeter speaker at an angle by the black connecting wire.
    • Desolder the black connecting wire using the Soldering Iron.
    • Soldering Iron will be hot and surrounding plastic can easily be damaged.
    • For soldering help, check out the How to Solder and Desolder Connections guide.
  18. Logitech UE Boombox Tweeter Speaker Replacement: 18 단계, 이미지 1개 중 1개
    • Hold the tweeter speaker by the newly disconnected end using flat-head Tweezers.
    • Simultaneously unsolder the thin silver wire using the Soldering Iron while lifting tweeter speaker away from the device using flat-head Tweezers.
  19. Logitech UE Boombox Tweeter Speaker Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the two 7.0 mm screws with a Phillips #2.
  20. Logitech UE Boombox Tweeter Speaker Replacement: 20 단계, 이미지 1개 중 1개
    • Unsolder the black connecting wire using Soldering Iron.
  21. Logitech UE Boombox Tweeter Speaker Replacement: 21 단계, 이미지 1개 중 1개
    • Hold tweeter speaker by newly disconnected end using flat-head tweezers.
    • Simultaneously unsolder the thin silver connecting wire using soldering iron while lifting tweeter speaker away from device using flat-head tweezers.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Wesley Kamau
회원 가입일: 09/15/16
227 평판
안내서 1개를 작성함
CSU Fullerton, Team 1-1, Bruce Fall 2016 CSU Fullerton, Team 1-1, Bruce Fall 2016 회원
CSUF-BRUCE-F16S1G1
4 회원들
안내서 5개를 작성함
1가이드 댓글
Could you recommend anywhere to find the correct replacement tweeters & drivers?
Ted Glasgow - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 13
전체 시간: 926
