필요한 것
Separate the back of the device from the face by inserting the flat end of the nylon spudger into the corner of the device to safely pry it open.
Solder the wires off that are on the battery. Use the solder technique guide for helpful tips!
Remove the 4.1 mm screws from the motherboard using the J #000 Phillips Screwdriver.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
