소개
This replacement guide will show you how to replace the speaker for this device. It is a simple and easy procedure that we will show you how to do at home step by step.
필요한 것
Separate the back of the device from the face by inserting the flat end of the nylon spudger into the corner of the device to safely pry it open.
Remove wires from the device with a solder iron. Use the soldering technique guide for helpful tips!
거의 끝나갑니다!
결론
