주요 콘텐츠로 건너뛰기
MSI GT72 2QE Dominator Pro Battery Replacement
필요한 것
  1. MSI GT72 2QE Dominator Pro Battery Replacement, Battery: 1 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a Phillips screwdriver to remove the seven 6mm screws from the bottom of the laptop.
    • Lift and remove the bottom case off of the laptop.
  2. MSI GT72 2QE Dominator Pro Battery Replacement: 2 단계, 이미지 1/2 MSI GT72 2QE Dominator Pro Battery Replacement: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove one 4 mm screw and one 10 mm screw from each fan.
    • The 10mm fan screw won't actually come out, as it is attached with rubber piece to fan. Unscrewing it from the lower case will allow for removal, though.
    • Unplug both fans by gently disconnecting the fan connector from its motherboard socket. If you have trouble, gently wiggle the connector to loosen it.
  3. MSI GT72 2QE Dominator Pro Battery Replacement: 3 단계, 이미지 1/1
    • Unplug the SATA cable and remove the hard drive.
    • Make sure to pull cable straight out in order to ensure it stays intact.
  4. MSI GT72 2QE Dominator Pro Battery Replacement: 4 단계, 이미지 1/1
    • Remove two 6mm Phillips #0 screws and remove the M.2 SSDs.
    • Make sure you pull SSD straight out so it doesn't get damaged.
  5. MSI GT72 2QE Dominator Pro Battery Replacement: 5 단계, 이미지 1/1
    • Unplug both red and black speaker cables. Pull straight out so the connectors aren't damaged.
    • Disconnect both these cables carefully by lifting the pressure tabs then gently pulling.
  6. MSI GT72 2QE Dominator Pro Battery Replacement: 6 단계, 이미지 1/1
    • Unplug the battery cable.
    • Pull straight up so as not to damage pins.
  7. MSI GT72 2QE Dominator Pro Battery Replacement: 7 단계, 이미지 1/1
    • Remove 15 5mm Phillips #0 screws and remove inner case.
    • Case may take some force to remove, but don't apply excessive force or you risk breaking the plastic connector tabs.
  8. MSI GT72 2QE Dominator Pro Battery Replacement: 8 단계, 이미지 1/1
    • Use a card or other flat object to lift and remove the battery from the housing.
    • Be extremely careful removing the battery. If punctured, hazardous chemicals can be released, or the battery could catch fire or even explode.
  9. MSI GT72 2QE Dominator Pro Battery Replacement: 9 단계, 이미지 1/1
    • Replace the battery with a 11.1V, 7500mAh Li-ion battery, MSI part number: BTY-L77 or equivalent.
    • Run MSI Battery Calibration to make sure the firmware can see the new batteries cycle high low voltages.
결론
다른 29명이 해당 안내서를 완성하였습니다.
Kevin Shipp
회원 가입일: 04/18/17
950 평판
안내서 1개 작성함
Cal Poly, Team S17-G2, Banghart Spring 2017 Cal Poly, Team S17-G2, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G2
5 회원들
안내서 7개 작성하였습니다
댓글 17개
Hi,
on the steep 7, you forgot a screw : just above the orange part of the heat sink.
great guide otherwise :D
Assombrance Anderson - 답글
And another one near the bass speaker
Did it but I was left with one screw. Have no idea where it goes. But hey battery works and not complaining.
Andres Estrin - 답글
Anyone know where to find a GT72 Dominator battery?
Hunter Gronkowski - 답글
I bought mine here: http://www.fr-batterie.com/
Thanks for this tutorial!
I used it to replace my GT72 2QD Dominator battery. It’s almost the same (yet, not a piece of cake).
Cameron -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 61
30일 전: 248
전체 시간: 48,440
