주요 콘텐츠로 건너뛰기
MSI MS-1782 Battery Replacement
필요한 것
  1. MSI MS-1782 Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Battery Replacement: 2 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 2 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 2 단계, 이미지 3/3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Battery Replacement, Cooling Assembly: 3 단계, 이미지 1/3 MSI MS-1782 Battery Replacement, Cooling Assembly: 3 단계, 이미지 2/3 MSI MS-1782 Battery Replacement, Cooling Assembly: 3 단계, 이미지 3/3
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  4. MSI MS-1782 Battery Replacement: 4 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 4 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 4 단계, 이미지 3/3
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  5. MSI MS-1782 Battery Replacement: 5 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 5 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 5 단계, 이미지 3/3
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  6. MSI MS-1782 Battery Replacement: 6 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 6 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 6 단계, 이미지 3/3
  7. MSI MS-1782 Battery Replacement: 7 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 7 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 7 단계, 이미지 3/3
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  8. MSI MS-1782 Battery Replacement: 8 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 8 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 8 단계, 이미지 3/3
    • Gently lift the heat sink and then pull forwards towards you.
  9. MSI MS-1782 Battery Replacement, Battery: 9 단계, 이미지 1/3 MSI MS-1782 Battery Replacement, Battery: 9 단계, 이미지 2/3 MSI MS-1782 Battery Replacement, Battery: 9 단계, 이미지 3/3
    • Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
    • Gently disconnect the cable connecting the M.2 caddy to the motherboard.
  10. MSI MS-1782 Battery Replacement: 10 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 10 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 10 단계, 이미지 3/3
    • Remove the 3.6 mm screw holding the M.2 caddy in place using a JIS #1 screwdriver.
  11. MSI MS-1782 Battery Replacement: 11 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 11 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 11 단계, 이미지 3/3
    • Gently disconnect the two blue ribbons.
  12. MSI MS-1782 Battery Replacement: 12 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 12 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 12 단계, 이미지 3/3
    • Remove the 5.1 mm screw holding in the disk reader using a JIS #1 screwdriver.
    • Use an iFixit opening tool to push the back of the disk reader to push it out of the laptop's chassis.
  13. MSI MS-1782 Battery Replacement: 13 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 13 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 13 단계, 이미지 3/3
    • Gently pull the disc reader out of the laptop.
    • Lift the plastic cover and disconnect the cable connected next to the speaker.
  14. MSI MS-1782 Battery Replacement: 14 단계, 이미지 1/1
    • Remove the five 5 mm screws holding the frame in place using a JIS #1 screwdriver.
  15. MSI MS-1782 Battery Replacement: 15 단계, 이미지 1/3 MSI MS-1782 Battery Replacement: 15 단계, 이미지 2/3 MSI MS-1782 Battery Replacement: 15 단계, 이미지 3/3
    • Pry up on the battery frame with an opening tool and unclip from the main chassis, working your way around the laptop.
    • To remove the battery, pry up on it to unstick the adhesive.
    • A little Isopropyl alcohol under the battery can help unstick it from the frame.
결론
Enmanuel Mota
회원 가입일: 03/08/23
229 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 61
전체 시간: 495
