소개
Use this guide to replace your mini's PRAM battery.
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
When putting back together:
Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
Remove the Mac mini Logic Board Removal tool.
Use the tip of a spudger to carefully pry the PRAM battery up and out of its holder on the logic board.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 5개
"Parts: No parts required. “ This is not true, since a new battery is needed to replace the old battery.
BR2032 are hard to find.
CR2032 also work
I got mine recently from Amazon for $4.
ccfman2004 - 답글
