주요 콘텐츠로 건너뛰기
Mac mini Late 2018 Antenna Plate Replacement
필요한 것
  1. Mac mini Late 2018 Antenna Plate Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Power off and unplug your Mac mini before you begin.
    • Use an opening tool to pry the bottom cover up off of the Mac mini.
  2. Mac mini Late 2018 Antenna Plate Replacement: 2 단계, 이미지 1/2 Mac mini Late 2018 Antenna Plate Replacement: 2 단계, 이미지 2/2
    • Lift and remove the bottom cover.
    • To reinstall the cover:
    • Align it carefully so that the words "Mac mini" can be read when the ports are facing you.
    • Then, press down on the cover to snap its three hidden clips into place.
    • Remove six TR6 Torx security screws securing the antenna plate, of the following lengths:
    • Three 4.1 mm shoulder screws
    • Three 1.8 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Mac.
  3. Mac mini Late 2018 Antenna Plate Replacement: 4 단계, 이미지 1/2 Mac mini Late 2018 Antenna Plate Replacement: 4 단계, 이미지 2/2
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the Mac mini's ports facing you, carefully lift the antenna plate and slide it about an inch to the right.
  4. Mac mini Late 2018 Antenna Plate Replacement: 5 단계, 이미지 1/2 Mac mini Late 2018 Antenna Plate Replacement: 5 단계, 이미지 2/2
    • Use a T6 Torx driver to remove the 2.8 mm screw securing the antenna cable to the Mac mini's logic board.
  5. Mac mini Late 2018 Antenna Plate Replacement: 6 단계, 이미지 1/3 Mac mini Late 2018 Antenna Plate Replacement: 6 단계, 이미지 2/3 Mac mini Late 2018 Antenna Plate Replacement: 6 단계, 이미지 3/3
    • The antenna cable connector and socket are fragile.
    • Use the point of a spudger or fine tweezers to gently pry the antenna cable connector straight up off its socket on the logic board.
    • To reconnect the cable, use tweezers to position it carefully over its socket on the logic board, and then press it straight down until it snaps into place.
    • If you need more slack in the cable, you can temporarily pry it from the clips securing it to the antenna plate.
  6. Mac mini Late 2018 Antenna Plate Replacement: 7 단계, 이미지 1/1
    • Remove the antenna plate from the Mac mini.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
410,093 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,743개 작성하였습니다
5 댓글
Wow, I have no problem doing this, but I walked my parents through a RAM upgrade on their 2014 Mac Mini when all you to do is remove the bottom cover and pull the modules out. I’ve already told them to skip this model. Great guide, I have the board in front of me and waiting for Amazon to deliver the new RAM today. Thanks!
willg - 답글
“a RAM upgrade on their 2014 Mac Mini” should be “a RAM upgrade on their 2012 Mac Mini”
willg -
What’s the antenna cable for? My WiFi works without connecting it
Achyuta A - 답글
Me too.It just works without plate. Not sure whether it’s assistant antenna for further and reliable signal… or just fake parts to check whether users tried to tear down and give Apple chance to reject customer service…you know it’s quite fragile part.
Joon -
Broke the female connector in the process of replacing the ram. It detached from the board. It's there a way to fix it? Wifi signal is still working but not as strong. Everything else working. Thanks
Ignacio Sala - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 23
30일 전: 119
전체 시간: 7,686
