이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lift and remove the bottom cover.
Align it carefully so that the words "Mac mini" can be read when the ports are facing you.
Then, press down on the cover to snap its three hidden clips into place.
이 단계에 사용된 도구:Magnetic Project Mat$19.95-
Remove six TR6 Torx security screws securing the antenna plate, of the following lengths:
Three 4.1 mm shoulder screws
Three 1.8 mm screws
With the Mac mini's ports facing you, carefully lift the antenna plate and slide it about an inch to the right.
Use a T6 Torx driver to remove the 2.8 mm screw securing the antenna cable to the Mac mini's logic board.
Use the point of a spudger or fine tweezers to gently pry the antenna cable connector straight up off its socket on the logic board.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 5개
Wow, I have no problem doing this, but I walked my parents through a RAM upgrade on their 2014 Mac Mini when all you to do is remove the bottom cover and pull the modules out. I’ve already told them to skip this model. Great guide, I have the board in front of me and waiting for Amazon to deliver the new RAM today. Thanks!
“a RAM upgrade on their 2014 Mac Mini” should be “a RAM upgrade on their 2012 Mac Mini”
willg -
Me too.It just works without plate. Not sure whether it’s assistant antenna for further and reliable signal… or just fake parts to check whether users tried to tear down and give Apple chance to reject customer service…you know it’s quite fragile part.
Joon -
Broke the female connector in the process of replacing the ram. It detached from the board. It's there a way to fix it? Wifi signal is still working but not as strong. Everything else working. Thanks
