주요 콘텐츠로 건너뛰기
Mac mini Late 2018 Bottom Cover Replacement
필요한 것
  1. Mac mini Late 2018 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Power off and unplug your Mac mini before you begin.
    • Use an opening tool to pry the bottom cover up off of the Mac mini.
    I got as far as this step to do one thing, blow out all the dust. It was far enough and a lot of dust came out. I used a XPower A-2S to blow out the dust.
    nirv - 답글
  2. Mac mini Late 2018 Bottom Cover Replacement: 2 단계, 이미지 1/2 Mac mini Late 2018 Bottom Cover Replacement: 2 단계, 이미지 2/2
    • Lift and remove the bottom cover.
    • To reinstall the cover:
    • Align it carefully so that the words "Mac mini" can be read when the ports are facing you.
    • Then, press down on the cover to snap its three hidden clips into place.
    My antenna plate seems to have TR7 Torx security screws
    DougPA - 답글
    My Screws were also TR7, 2020 build
    Eric Ford - 답글
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
428,582 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,243개 작성하였습니다
댓글 2개
Where can i find the cover itself for MM 2018?
avxkim - 답글
Check eBay for unibody Mac mini bottom covers. You can also 3D print one if you want to.
Forrest OHara -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 26
30일 전: 117
전체 시간: 8,310
