이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Grasp the power supply cable and lift to disconnect it from the logic board, wiggling as needed to loosen it up.
Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board.
Use a T10 Torx driver to remove the two 7.5 mm screws securing the logic board.
Place a thumb at each end of the exhaust vent, over the fan screw holes.
Push firmly in the direction of the ports until the logic board unclips and begins to slide out of the Mac mini.
