주요 콘텐츠로 건너뛰기
Mac mini Model A1176 Bluetooth Board Replacement
필요한 것
  1. Mac mini Model A1176 Bluetooth Board Replacement, Top Housing: 1 단계, 이미지 2개 중 1개 Mac mini Model A1176 Bluetooth Board Replacement, Top Housing: 1 단계, 이미지 2개 중 2개
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Mac mini Model A1176 Bluetooth Board Replacement: 2 단계, 이미지 3개 중 1개 Mac mini Model A1176 Bluetooth Board Replacement: 2 단계, 이미지 3개 중 2개 Mac mini Model A1176 Bluetooth Board Replacement: 2 단계, 이미지 3개 중 3개
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Mac mini Model A1176 Bluetooth Board Replacement: 3 단계, 이미지 2개 중 1개 Mac mini Model A1176 Bluetooth Board Replacement: 3 단계, 이미지 2개 중 2개
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini Model A1176 Bluetooth Board Replacement: 4 단계, 이미지 2개 중 1개 Mac mini Model A1176 Bluetooth Board Replacement: 4 단계, 이미지 2개 중 2개
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini Model A1176 Bluetooth Board Replacement: 5 단계, 이미지 2개 중 1개 Mac mini Model A1176 Bluetooth Board Replacement: 5 단계, 이미지 2개 중 2개
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini Model A1176 Bluetooth Board Replacement: 6 단계, 이미지 2개 중 1개 Mac mini Model A1176 Bluetooth Board Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
  7. Mac mini Model A1176 Bluetooth Board Replacement, Bluetooth Board: 7 단계, 이미지 1개 중 1개
    • Remove the single Phillips screw securing the Bluetooth board to the internal frame.
  8. Mac mini Model A1176 Bluetooth Board Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the Bluetooth cable connector by pulling it straight away from its socket.
  9. Mac mini Model A1176 Bluetooth Board Replacement: 9 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the Bluetooth antenna cable connector up off the Bluetooth board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Walter Galan
706,213 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 8,474
