소개
Restore sound to your mini by replacing the speaker.
부품
부품은 필요하지 않습니다.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Remove the two Phillips screws securing the side of the hard drive to the internal frame.
다른 한 분이 해당 안내서를 완성하였습니다.
