이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Remove the top housing to access your mini's internals.
필요한 것
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
다른 47명이 해당 안내서를 완성하였습니다.
댓글 2개
Does this work to remove a disc
ajunelady6 - 답글
That's part of the process. After that, you will probably need to disassemble the optical drive.
Skylar -
