이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The bottom housing holds all your mini's internals.
필요한 것
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
We will first remove the AirPort antenna, located in the lower left corner of this picture.
Use the flat end of a spudger to pry the three antenna connectors off the AirPort/Bluetooth combo card.
Use the flat end of a spudger to pry the power button cable connector up off the logic board.
Remove the single Phillips screw between the headphone and microphone jacks on the audio board.
다른 3명이 해당 안내서를 완성하였습니다.
